now THATS an april fool :D
Heh the best bit is the instructions page, showing a guy in the sewer system with a snorkel... roflcopter
It'd be interesting to see how many people actually fall for it!
yeah, i called BS where it stated the free installation kit includes a roll of optic fibre cable :D
Old man rivers would die when a GT42 would come on boost/ More so from how they hit boost.
Old hearts cant handle that type of shit :O
rofl yep they do seem to be an animal!
theres one on a 26/30 33 gtr over in the uk, 647bhp @17psi, does awesome skids in 3rd :D
I was along side a supra with a gt42 with big cams, I have never heard a turbo so tough comming on boost then seeing it leave so quick.
Sounds like some of those turbs we saw on the rotors at the jam. Bigger than the engines they were. :D
yup.
but u saw what they were like if they stuffed up the launch and bogged them down, needed to half track to spin them up again :no:
joshwa, got my exhaust sorted. twin 2.5" dump pipes with 2.25"screamers to atmo, 3" from back of dumps into 4" straight through to muffler at the rear. send car off week after next :O
yup.
but u saw what they were like if they stuffed up the launch and bogged them down, needed to half track to spin them up again :O
joshwa, got my exhaust sorted. twin 2.5" dump pipes with 2.25"screamers to atmo, 3" from back of dumps into 4" straight through to muffler at the rear. send car off week after next :D
f**ken hot sauce. What muffler? I hope that puppy is on a flange for those times you jyst feel like pulling it off :no:
So close... So moist
yup.
Who's doin ya tubes and how much shane?
hhhhhhhhhhhhhhhhhhhhhhhhheeeeeeeeeeeeeeeeeeeeeelllllllllllllllllllllllllllllllll
llllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllll
llllllllllllllooooooooooooooooooooooooooooooooooo
