Dont get me wrong, im way too hung up having a street weapon just as much, but this is due to them being overall cheaper, better value for money performance wise and just a f**k load quicker then anything old school like i mentioned could be.
If I could, I owuld be driving something old
Interesting comment. I am still hung up on small block chevys but the dynamics of the skyline as a package are obliterating those kinks at a rapid rate. The only neg i see at this stage relates directly to my bogan drag racing heritage. The turbo lines are a beetch to get right on the launch. Everywhere else tho they far exceed the iron trucks.
I was born way too late, sometimes I think I should be in my 50's :D
But yeah, the overall pakage and dollar for dollar value you can't beat modern cars.
Now theres a front bar with a shovel lip i really like. where the hell is montrosehttp://www.skylinesaustralia.com/forums/index.php?showtopic=162905
Montrose is about 40 - 50mins east of the CBD.
You should be able to buy Msports kits in QLD...
Drifting has zero appeal to me. the people that do it are grubs and their cars are cops. Its the new bogan class of the motor world.
As if they are all cops some of the coolest cars I have ever seen are drift cars
Infact the orange one in the for sale thread you posted springs straight to mind!
Some of the cars are awesome, well set up and look smart. I admit pretty cars dint get me excite (not something I would wana own), i dont like them, they serve no purpose when your racing, however tidy well packaged cars are FTW.
Kudo's to people who put the effort in making them look pretty though, each to their own when it comes to owning them
Giggity
Perfect paint is for teh gheys but ha ha :D
True that! Dont get me wrong, finding a new mark or something on your car is annoying, but its not the end of the world, more so if it happened while out having fun, car park door marks is another story.
Perfect paint clowns I cant understand
I cant fault your argument here HI5
it turns u on
not now, the others will get jealosu
True....I should really say many of my favorite cars are drift cars
Back me up Liz dirty cars are hawt :D ha ha
this is true!
my silvia.. dirty little bitch she was
my skyline after the dirt drift day... oh she was one hawt mumma!
and my 180.. well, you can get f**ked if you think that's going anywhere near the dirt
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
