arent the roosters playing now andy??
Yeah and they suck balls
I wish they would play crap all the time so I didnt have any hope lol this roller coaster ride of being in games then collapsing is shitting me up the wall!
hahahahaha
on other news denver is on a 3 game winning streak and face the mavericks on sunday, if they win they go to the 6th spot in the west.
i think that denver could give either team a run for its money if it gets production out of JR Smith and Nene, they flogged the suns a month ago and the mavs have only beaten them by 5 points or less in 2 games this season.
IF iverson starts passing like he should i think that any team could be in trouble.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
