how can u not like eddie murphy!!!! hes a funny man, just like dave chappelle. now him and eddie murphy are on a par in my opinion.
One persons "funny" is not neccessarily anothers. I find up himself eddie quite booring actually.
fair enough.
u probably like sid james style comedy, carry on style!!!!
LOL, there was a time but that little top bloke in the carry on series got a bit much for me. I pretty much like anything funny (inc some eddie murphy stuff) Its just booring tho when all of his stuff is just look at me look at me type shit.
Bill Cosby and mr. Bean are another 2 faves.
I remember when those movies were on during my recovery afternoons on a Saturday...lol I hate that poofy little doctor
ha ha they are a bit out of date now, but in there day they woulda been classic. i still like dave chappelle, "IM RICK JAMES BITCH!!!!!! ha ha
oh and andy do they have stuff on there site about window motor/regulators etc at just jap or do u have to PM them....
I would just call them tomorrow
Yeah thats the one Andy. It got to the stage where i just wanted to hit the little twerp. If he wasnt a raging fag i would bet London to a brick he was Peewee's father. :laughing-smiley-014:
