yo bitches.. by my stuff please..
http://www.skylinesaustralia.com/forums/in...howtopic=168882
ill throw in a set of steak knives too..
*note steak knives are a fabrication of my imagination*
how does get f*cked sound? :D
same old shane.. sauqld's dick for head.
some1's gotta be it, right? :thumbsup:
im not snobby
you are shane... :)
i have tried twice to talk to two different R34 GTRs, but both times they ignored me completely....like they are too good...
why?? :wave:
as if i'm a snob! :wave:
were they of ur culture frank? :thumbsup:
dick for head
hahahahahahahahahahaha
lol indeed
so mark, whens graduation for the 6th grade?
as if i'm a snob! :thumbsup:
were they of ur culture frank? :)
lol indeed
Man, you have some anger issues you need to deal with.
You haven't got the size or strength to make that many enemies....lol
My car has been more of a garden ornament for a lot longer than yours and I'm not even that angry with the world.
ur just jealous caus i can stir shit better than you :)
yah! me and my homies........
you could have just said asians u know...
shane was trying to be nice..
i am impressed :laughing-smiley-014:
+1 for the anger management tho
i was going to say yellow, but hey i'm down with 'asian' :)
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
