nah 1.5 JZ
quick pass that one nearly as quick as shane's hybrid. pppffffffttt
there is no flow bench testing proving the 1j head is better then the 2jz head.
Why build a 1.5j for the hell of it? You'd only do it if:
a) your 1jz blew up
b) you had a high end 1jz head already built with a shagged bottom
I've done the cost's, starting from nothing its cheaper to just use a 2jz.
Edited by Nismo_Boy
josh i hope these cars ur bringing to the dyno day have got some decent power :)
One is a stock R32 with open pipes, the other is a "close too" 2.7lt, built head, motec, GT-RS turbos ect. We'll see, I wana tinker with timming and fuel to pop 400rwkw, my mate is being a pussy and just wants to roll on 18psi and pump gas. I say ban him!
mmm noise & flames, hell yeah thats some half decent hp :)
Only thing holding it back is bigger injectors.. :D
Nah should be good, I reckon it'll do 320 - 350rwkw on the day. Would be nice to bump the boost more and have a play to make a magic 400.. but it's not to be maybe i'll keep talking about it and convince him :)
a) your 1jz blew up
People build em for the response as well, not just for outright power.
if its power then 2 jz all the way....stuff opening it either. :)
lol what's it with people and under sizing their injectors? :)
soo ur saying the 2.5ltr 1j head would be more responsive than the 3ltr 2j? hows that work? lol :)
its like putting a rb20 head on an rb25....it flows less HP, as in the inlets etc are smalled....but from that it prevides better response...its like putting a smaller turbo on your car....but more expensive....there are a few other details that it changes too
come on shane..
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
