lol what's it with people and under sizing their injectors? :)
Car was built for reliable everyday horse power, not out right power. Your right though, while doing it why not just go bigger for later on.
Either way, a new set are coming
People build em for the response as well, not just for outright power.
if its power then 2 jz all the way....stuff opening it either. :)
I love toyota, and everything they have to offer, in fact i used to want a 1.5j. but go drive a 2jz 6 speed and then tell me they are not a responsive motor. I'm saying cost vs cost its cheaper and more easy to go 2jz, unless you have a big dollar 1jz head already, or you are doing some of the work your self
Edited by Nismo_Boy
I am not having a winge stig man, just lookin out for me fellow stigs.
i'm not talking about you....but thanks for the heads up...i've seen much worse posted on here...but that was in the old days *cough* Charly *cough* I think the mods will be fine with what i've said. I just don't like someone claiming to be police stating things that are clearly wrong.
IMO the QLD Police would find his comments offensive. He has said that officers decide the severity of the fine based on the attitude of the driver and not the law they have broken. Thats not how it is supposed to be done. He also advised that we loosen dump pipe bolts to get the same effect as a sceamer..erm no and it's also illegal. Then he says all mods are illlegal unlees engineer's approve them. That is clearly wrong and even the basic Transport modification guide says so.
as far as i'm concerned I doubt he's even a Police Officer and if he is, I fear he's one of the ones that do fine people incorrectly making us go through the court process to have it cleared.
What's happening Bitchez?!?!?! >_<
:wave:
hey hey :wave:
missing ur anna much?
come down to aarons dyno day ! only like, 4 SAU members signed up so far.. disappointingly small. especially if we get outnumbers by Boost Cruising kiddies =\
i'd go...if i had a running car :P
Hey you...
we been having discussions...yay!!11one!!!11 fun fun.
whats you been doin girly?
Nuffin ..
Bored shitless :(
Trying to pass time at work and havn't been on here for ages :P sooooooooooo .. thought I'd pop by to say Hello!
"Hello!" *waves*
haha
>_<
hey hey :wave:
:wave:
Yesh :(
Missing her soooooo much!! Mainly because I know she's so far away haha BOOO!!
How have you been mister?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
