hahaha might be a fair match then
youll still have awd though
and you'll have ~200kg's on me lol
Use broom handle and fencing wire, Thats all you need for good handling on a parked car. :blink: :laughing-smiley-014:
spose it seems to work on that land barge of urs :D
Shanef: Get that f**king car of yours ON THE ROAD. And let it do all the talking for you. :blink:
which nut do u wanna suck, the left or right? :D
i'm enjoying the stirring, i just hope i can deliver when the time comes lol
thats what its all about
damn right homie...although it doesnt actually have a badge on there atm! :D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
