stuffs me why you got rid of the ST. That was a very clean example.
it certainly was, spent a fook load on the biatch too, only thing it was missing was a rebuilt donk and decent sized turbo. but, the gtr bug bit me and i spent 4 months or so with the urge to get one, and i did!
but ahwell, i know the guy who'se got it now, so i can always get it back down the track
noob i would not worry this is whoretown, you can say anything you want...
Go hard, just mind the swear words during the day so it work safe...
blow me pony boy.
blonde faggots dont do it for me... i rather gramps over in the corner then you anyday
Edited by jibbz
