A saw a mighty boy for sale, it says 4wd turbo.
So i had a closer look and year it was fully evo running gear...
The owner says its stock as a rock and runs a 55 lap round QR sprint... Thats quick as...
But when you car weighs less than 600kg's i guess thats expected... :)
Would be fun!
Well im off to my "State of Origin" lunchen, then onto the XXXX brewary and then on to the game to enjoy front row seats on the 50 metre line and then back to XXXX keg room to finish the night off...
Enjoy your day people... Ill talk to you all tomorrow night when Im sober again... :)
Bring me back free beer.
Yeh used Du Point acrylic. My brother painted the car, he needs more practice before he did an out side job, just been doing mates car for around 8 months.
how 'durable' is acrylic compared to 2pack do you know?
i need my car done, and wanna get it in midnight purple/pearle, same as my engine bay. any idea when he wants to do 'outside' jobs and what he'd charge? i can rub it back too, soo all i need is some1 to spray it
Acrylic is easier to spray and make look right, 2pack is thicker and harder to spray and get looking nice. I'd say due to the 2pack being thicker it would be more durable, however you do enough coats of acrylic it will be fine, plus with enough clear it'll look deep.
He would do it now, but I doubt you would be happy. He still has a lot to learn thats all.
Normally it's around $500 plus paint for it to be sprayed.. Depends weather you supply your own cutters/polish (some people prefer certain products). You get what you pay for eh
give me a heads up when u reckon he's up to scratch :)
i'll hit u up for more info then
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
