So what box are you going to go...how much power are you intending to make? The os giken and ppg gearsets have been used in some pretty high hp cars that do regular track days. You aren't going to go with something dog engagement are you, talk about spending your weekends stripping down your box to check everything out after a day at the track....no thanks.
800bhp is what i've speced everything else to, but prolly be lucky to make 750bhp. i know theres some pretty decent hp cars usin the os kits, but then theres just as many people who have broken os kits. Also from what i've seen you only strip down a dog box after a year of racing, just to check it then.
I dont know, from what I researched when I was looking at boxes, dog boxes are very high maintenece, especially if driven on the street as they don't select gears well. Also unless you opt for billet selectors they have an even shorter life span. I am pretty sure SydneyKid was saying they strip their boxs after almost every race meet as it's necessary to check for problem components...and iirc he was talking about how they had to replace items rather regulary as they started to wear down. I think they are perfect for track only cars, but a bit of a problem for street driven cars.
periodic maintenance far outweighs the need for a complete replacement if u do smash an os set, @~5k for a ready to go os 5speed
plus theres the likelyhood of this gtr becoming a track only car, i can see it happening
From a back yard car to a track only car. Thats quite a contrast :domokun:
From a back yard car to a track only car. Thats quite a contrast :P
you like? :domokun:
P.S eat a dick fanboy
http://www.skylinesaustralia.com/forums/in...c=159419&hl
there's a more recent article on the ppg dog boxes....
yeah i read that, and i aint goin ppg lol, i've seen 1 ppg break, and whitnessed issues with another on the weekend (the later bein a 2 weekend old box, the other a 2 yr old box)
all I can say is I can't wait to see and go for a ride in your car once its finished Shane!!
i'll be the first to say it...youll be waitin a while lol. the engine's nearing finish time and startup, but theres the suspension side and braking side i gotta take care of before i go spastic with driving it in anger
all good things take time....or lots of money.
you know you can drive when you can drive with a dog box too....good bragging rights :P
that and coupled with a super light twin setup :P
Im looking foward to racing it :)
it'll be interesting to see indeed!
i would say u'd have me from down low, but seeing a result with a built 26/30 coupled with a TO4z from UK, 1bar by 3200rpm on the run in tune, i reckon i'll be on song very early! :domokun:
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
