Bah i got one of our unit people who is a mechanic to give me a hand with them cams, everything going well, and then bang, fkn broke a stud of I6 capstud, didnt even move a bit broke straight away, You would have a spare bearing stud would ya dan? i need one or know where i can get one, IE: repco?
if ya talkin cam bearing I can loan you one and you can replace it. I will need it next week tho.
And yes i followed the correct procedure blah blah blah in how to remove cams etc before ANYONE asks. Yes i have a torque wrench, i also have the manual and i took extra care etc etc didnt rush it....
Cheers
A
You won't be able to get one as they are line bored to match the head. The one you lend will not necessarily be the same as the one you get back
May not fit
Studs aren't available from anywhere really. You gotta use a M6 cap stud or something similar and tap the hole out to suit
You can helicoil too if you like
You can buy replacements for the rb26 the tomei ones, but i just need one not 28 of the fookers, and it happened to the intake or bearing cap I6 as numbered on them the one with the brass plate attached to it, and yes dan is correct about the bearings as there machined for that specific engine, looks as if it was going to break either way who ever did it as it broke almost instantly first slightest pressure on the damn thing....
Bit of stud broke inside :O thats what i thought about the stud theory should be able to just threadtech the old one out and replace the stud like any studs head manifolds etc
That what i thought too Adam.
Hello Queenslanders... im coming up from 3 to 13 june from Melbourne, ive been before but would like some ideas on.....
what to do and where to go
and
What are some good places i can hit in Brisbane City?
And can someone tell me what is with the terrible taste in cars/mods in QLD.. like lancers with big chrome wheels, vinyls and pink interiors etc...
thanks :O
and
thanks :O
The dunrootin old folks home does bingo every tuesday night and the pink Lancer belongs to Adam.
the name 'adam' sounds about right for a pink lancer, and bingo on a tuesday night sounds delightful, i want to yell out 'legs 11'..... then all the old ladies can show me their legs and then :O
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
