lol shane... tsk tsk
what u talkin bout fool? :thumbsup:
look for Isleep on the forums and you shall see noel, oh and for the plenum, you can always sell the bottom runners to him for 80-100 delivered to him as he is looking for them as there is a very very lack of such runners :sleep: plus is a better design and flow characteristics compared to the greddy item :laugh: cheers
i'll drop him a pm then :cool:
Oops and yes dyslexia may be a vision disease but the freq hz of such images related to fits and the like is related to epilepsy, hence why most of these type people are not allowed to drive as theyll crash :|
Oops i forgot one thing, They're shiny, oh so shiny my bling is on the inside of the engine bay not outside the car lol
Shiny! You mean like your tyres. :cool:
hhahha
http://youtube.com/watch?v=7lK_B_nhRVU&amp...ted&search=
i cant tell if he meant to do it, or was simply trying to record himself doing wieghts and it went bad
Edited by Silver_R34_GT-T
the snail looking thing on the passenger side of the engine is a turbo. ther is a line leading to the brass round thing on the turbo.. (wastegate) pull that line off... u will have a nice boost upgrade. no harmful side effects either
I can't believe you would suggest something like this on a public forum.
It could not only destroy the turbo but almost certainly destroy the engine if other failsafes don't work correctly or don't react fast enough.
lol yeah, tried it, uber boost man, but it made this clank and now it won't start right :) (lol, kidding, also, it has the heatshields still on so you can't see shit of the turbo :D)
Was trying to find where the coilpack loom ran but I've got it, now I just need to find out which pin on the CAS is it's 12v.
Edited by Hell Fire
If you have a drama you want sorted out, email me, msn me on [email protected], or phone on 0407 111 229. I can talk you through any disgnostics if you like
results are in 232rwkws on richos dyno, damn ting melted my back bar :) some modding to do tommorow, fkn cams have made it a lightswitch to come on boost
What type of cams did you get and who fitted them for you.
u forgot to mention u only answer ur phone 30% of the time :)
post dyno graph yeah?
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
