i was thinking more northside... and nah not markimark, was thinking shanef mechanic though
haha im down with that
^^^^^^^^^^^^im booking my car in with the shanef suspension shop on the weekend. Hopefully you are still up for it shane.
Suspension
Handling
And
No
Emo's
im down with that, and no, no emos
In that case, my mobile is being switched off.
u see i could be really smart and make it the same day as the day we're at noels, and accidentally give sub noel's address :D
u see i could be really smart and make it the same day as the day we're at noels, and accidentally give sub noel's address :woot:
Hey thats a good idea, maybe Dan can put in some cams for me as well.
:D:(:(
$490?.....Geez I don't charge much more than that to install the FULL whiteline package. Bushes, bars, struts and all.
Camshafts? No problems....just make sure shane can watch...I'd like him to see what a whole one looks like.
yeH I THOUGHT it was pritty hgih
i called redcliffe springs and suspension and told them i had the kit and what they charge to install, and they told me they dont do coilover
wtf
all you need is torque wrench, radiator fluid, patience, several sockets, aircompressor, impact wrench, 1 uni joint for socket, 1slab of beer, maybe a jack depends if you have a front mount or not, and 1 day to spare, also doesnt hurt to have a few spare studs just in case :D
zomg
i was walking my dog with my mum before and we walked past a house with a tripple garage
anyway he doors were open, and holy crap
he has, a bmw x5, a brand new jaguar sedan, and a old old style jag in mint conditioon with the white wall tryes.. anyway
to be even more amazing he has a hydrolic mechanic lift thing like a professional one, holding a carivan up in the air, and his jag sedan parked underneither it
now thats crazy,, :S
zomg
Couple of guys in the Porsche car club have something like that. We priced up a hoist at one stage, they are really are worth it if you have the room.
is there a DIY tutorial on sau or anywhere
DO A SEARCH U FOOKING RETARDO
but they look heaps better split in half :(
and i've only snapped std ones thank u, although im yet to touch an aftermarket set :D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
