Someone is bound to ask why... see attachment :(
thanks for that chris.. low down.. do u understand..
ouch, its that really ya car? or are you making a funny
not funny when my bro rights off
now i get it, marki hit something last nite...
details!
morning kent.
no my brother was travelling thru kuraby estates and went around a blind corner, was too close to the curb and too evasive action to avoid a parked car and it upset the car started to oversteer. hit a 30x30x200cm concrete fence block and spun and hit the rear on the next block then it stopped..
still looking at damage
HOLY CHIT
:( no one was hurt this time
insurance? u makin him pay?
id bet them rails are damaged, not cool dude :(
technically its his car. as he drives it and all i just built it.
insurance was CTP ONLY.. which is unfortunate.. ;)
only the rails on the front was damaged and boot was buckled in by 15 odd cms. 2 TE37s where buckled too and have loss pressure so hopefully we can salvage that..
the ohlin coilovers where not damaged.. cost the owner 6k supplied and fitted and are 5,000kms old we'll be putting it up for sale soon for around 2500-3500 as we need the cash for the next project.. :(
im thinking about building.. wait for it..... RB25NEO 180sx :(
insurance was CTP ONLY.. which is unfortunate.. :(
soo ur parents bought the car then?
6k for ohlins? he got ripped off ;)
haha ur a crack up, before u were bagging the rb compared to the sr, and ur going to do a 'project' rb 180? :(
P.s rohan, i love ur cold heartdness :sorcerer:
hehehe, man hook me up with a job, working 4 days a week as a casual just aint cutting it
lol,yeah come work @ Clipasl my job just Opened up, lol only there 3 weeks and now the have made me Warrenties Officer and Service agent director for all of Queensland.
the bad thing is i;m still on probation so the pay is still to be fully arranged. i'm still only on entry level pay.... just wait 2 months down only 4 months to go...
haha ur a crack up, before u were bagging the rb compared to the sr, and ur going to do a 'project' rb 180? ;)
thats ur prob shane u dnt do ur research haha.. oh well..
1. they are top line coilovers but u wouldnt knw u use shocks and lowered springs..
2. WE didnt buy them they came with the car as part of a deal :P
haha we are using a CA18 shell car and putting a RB in it... would anyone put a iron cad RB in a SR shell haha please..
anyway ladies.. no damage to the engine yay... and my next RB conversion is gonna go hard.
2. WE didnt buy them they came with the car as part of a deal ;)
i do my research little man, and for 6k u could get a set of protek suspension, plus u'd have 2k spare from a set of 50mm dms suspension, ohlins arent that expensive u douchebag ;) fark i'd want a set of sachs for that kinda coin :P
u feelin me?
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
