well the way i see it michael.
I've gotta get atleast pistons, there ~1200, then machine work, ~1k, then may aswell get rods aswell 890, then whats the point in putting the shitty stock head on with that fully built bottom end (have got all studs, bearings, acl headgasket now) when i have the ported blank head there that will be going on at a later date.
the budget i set aside to get the thing running by december didnt include new pistons or the likes, so this year is now certainly outta the picture. im over it, anyone got a light? sigh
Can i ask why you didnt allow for pistons and rods? I thought you had all those things already?
Crank isnt a big deal, if its just scoring its easy enough to go 10 or 20 thou over size.
Who would be doing the machine work if your getting the bottom end done? Cause you would need to do it right, since your aiming for big power....and i dont know how many shops out there know the tricks you need to do inorder to do it properly.
when i bought the bottom end, i was told it had forged pistons in it, hence not needing new ones, and not budgeting for them.
nah crank s easy, dan's got a spare he was gonna throw out lol. theres grooves worn in the front and rear oil seals, and the crank pulley gear woodriff key hole is rounded off!
dan's getting me all the parts, and he's getting chilton to do the bottom end work, i'm getting john hill to finish the porting in the head.
looking at a gt42r with the .90 rear and a set of jun 272 11.35 cams, with .5mm os inlet & 1.0mm os exhaust valves
you going to jambo tomorrow? So long as the rain pisses off!
yeh mate i'll be there ;)
haha ur not cut r u marki? :banana:
nope.. shane u dnt annoy me... much...
anyway
UPDATE.. the lil scratch and dent i have is hardly noticable.. lil bit of body deadner here a bit of polish there and u got to look for it to see it.. and best of all none of this damn rain is gonna turn my iron horse into an iron oxide POS like shanes ornament :laughing-smiley-014:
ROUND 2.... FIGHT ;)
ahaha.. shanes gay i aint.. got a lady.. ahaha... :sorcerer:
u think ur box.. he knows i can box..
http://www.hardcoreware.net/image.php?src=...p;ts=1047529501
yes marki u may have a lady, but u believe in no sex b4 marriage. me on the otherhand, im not tied down, yet im still getting sex rofl
yeah I heard that shane was getting it on with 6 chicks at once.
by the way can you say hi to Mrs Palmer and her 5 daughters next time you see them shane.
and about your car dont get too down, save your money for the bits you need and then im sure everyone will chip in to give you a hand to finish it. Hell ill even risk my manicured nails to help.
BUT SHANE YOU HAVING BUTTY SEX WITH NOEL DOESNT COUNT AS SEX..
noels gonna be pissed
yehh, ur farked :banana:
them bitches wear u out fast aye. they were saying last nite that they wanted to see their dad and 4 brothers again. any idea when u'll be finished with them?
i can do most the work myself (within reason) so that's no problem, it's just the farking mula. to get it running i'm now looking at close to 20k ;)
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
