how much oil exactly should be put in the rb25s ;)
i ask, becuase yesterday we changed my brothers oil, and he got 4 litres
today we did mine and i got just under 5
It should be 5L
Whats this cooler Marki, i took the front bar off when it went for a ride on the tow truck.
haha thats all custom.. nice end tanks though who did that..
BTW ur chromies make me puke!!!
cheers james, ;) im glad mine had the right amount lol...
so is it a GKtech kit..?
SOMEONE BUY THIS IT PAINS ME TO SEE THIS FORSALE
cheers james, :thumbsup: im glad mine had the right amount lol...
Did you turn it over and then check the level again the oil filter drinks a bit, im sure if he checks it. It will need topping up. ;)
I will get you a bucket.
Or hang on
Fark you ;)
whats wrong with em, there nice and shiny.
Are you do know what ur on about, and Shane told me you were just full of shit.
I believe it was subzero.
And your a gaylord he told me that too.
u just angry that ur precious jambo was cancelled
WTF are you on about mudcrab. jambo has not been cancelled. Its only the softcock drifters that wont run in the rain. Must be frightened they'll get sideways. ;)
Tell me more about the wheel on the right sub, what is it, cost etc. I kinda like it.
Yeah its not bad eh, i know fark all about it :laughing-smiley-014: i just saved the pic and thought they look good. I cant even remember were i saw them.
And you are all crack heads. Subs whiteline looks hot as in the flesh. It carrys the chrome full hektik sic. ;)
Thanks bloke, they got dish and they fit my 285s sweetly. :thumbsup: , but i would like some 19s in black and chrome.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
