there was an opening for u to stick ur little pecker in and u declined
FAIL
Errm, she was a bigger build and her friends were sniffing lines in the toilets. Neither of us liked her. Plus, no loss I got sex monday.
How's not getting laid going shane
the fatty's need lovin too :blink:...apparantly
dunno man, havnt had to worry about that for a few months lol
is it jsut mean, or since that new site, sauqld.com thingy has started, this qld section barely gets used :(
SAU QLD was started because of issues with this board, these issues never ceased so yeah I suppose less people do use this now
Love toyota's as much as me Andy, you know u wana
shit yeah.. used to love working on the imports.. MR2GT supra starlet GTs and the odd chaser.. cause non of the bogan kents would touch em thinking jap shit and all that v8 owns yada yada.. that was a plus at toyota lol
I have wanted a JZX100 for ages!
And the 110 looks even better but I have never seen one available!
JZX110 are pure porn!
plus no plates for 110 on the complaince list :(
its a bummer hopefully j-spec or prestiege gets them soon
And 1j pwns all except 2j
+1
I just watched some net porn and it would appear i am growing in the right direction. I got a farkin boner like a donkey. :(:P:thumbsup:
bahaha funny post of the night
nah ive seen your mum giving em to your dad to keep up with me, he couldnt quite meet me in the stomach
2nd funny
I want a chaser now
who doesnt.. apart from shane.. but put him in the passenger leather heated seats. pop second brake then handbrake while turn in. trace wheel back and counter at 80kph in a friggen 4 door sedan that aint an overused GTST 4 door :ninja: u knw what he will be doing... :nyaanyaa:
Will u let me drive it?
me too. ill pay cash
good thing im not a red nut...GINGER NINJA :ninja:
bahaha
geez i had not bothered to look at that chaser but sheesh it very noice!
dano have u been living under a rock.. its basically a 4door supra.. :(
quick question josh do anything toyota apart from JZA80 come with the 6speed getrag?
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
