just went an looked again its an 044
this is the setup on offer
http://www.skylinesaustralia.com/forums/in...t&id=115512
thing is im looking for a pump and have seen this for like 150 more so thinking it might be the go
shanef has his 044 for like 220 but its unused
yeah but dont buy anything off shane cause he is a tool..
nah hes a good bloke.
farken shane send me a msg to remind me to send you that stuff i did..i keep forgetting.
is $350 a good price for a surge tank 040 and stock feeder pump?
fookin oath it is
yup, it's only been mounted in the tank (no fuel in tank mind u)
if ur running it externally (whiche im sure u will be) i can give u the list of fittings u need :thumbsup:
done bish, c u tonite ;)
oh your on here now....
ye what little i have had talkin to him. he his have shits with his email, so am still waiting to recieve stuff both ways...farken east timor shit.
but from what he says it shouldn't be a problemo, just got to make sure it gets wired in right ey ey.
peace brovah
u on the piss again?
P.S dinner is at jacks tonite, always plenty of skanks around there :thumbsup:
touche
i forgot about that. see how many we can get pisshed off ey.
nah not drinking...pitty....just at work kinda cant concentrate atm...i just hit puberty and the hormones are yelling obsanities at me for obvious reasons.
well you old nigah...as i said in the the cruising thread that it was in i have a seat spare..well 2 seats really...but if yah want to come then let me know.
Edited by Oblivion
IF YOU WANT TO DO RIPPING THERE WILL PLENTY OF LITTLE CHILDREN ......
BUAHAHAHAHA
MUHAHAHA
JUST KIDDING FOR EVERYONE WHO THINKS I AM SERIOUS...AND CAPS IS STILL ON...FARKEN.
charity FTW
bogans FTL
by charity i will assume you mean the greedy lazy pricks who masquerade as a charity in order to sponge money from us because they are too farkin lazy to get a real job.
Gotta love the way the bastards use the cripple and dying to make a buck. :thumbsup:
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
