just went an looked again its an 044
this is the setup on offer
http://www.skylinesaustralia.com/forums/in...t&id=115512
thing is im looking for a pump and have seen this for like 150 more so thinking it might be the go
shanef has his 044 for like 220 but its unused
yeah but dont buy anything off shane cause he is a tool..
nah hes a good bloke.
farken shane send me a msg to remind me to send you that stuff i did..i keep forgetting.
is $350 a good price for a surge tank 040 and stock feeder pump?
fookin oath it is
yup, it's only been mounted in the tank (no fuel in tank mind u)
if ur running it externally (whiche im sure u will be) i can give u the list of fittings u need :thumbsup:
done bish, c u tonite ;)
oh your on here now....
ye what little i have had talkin to him. he his have shits with his email, so am still waiting to recieve stuff both ways...farken east timor shit.
but from what he says it shouldn't be a problemo, just got to make sure it gets wired in right ey ey.
peace brovah
u on the piss again?
P.S dinner is at jacks tonite, always plenty of skanks around there :thumbsup:
touche
i forgot about that. see how many we can get pisshed off ey.
nah not drinking...pitty....just at work kinda cant concentrate atm...i just hit puberty and the hormones are yelling obsanities at me for obvious reasons.
well you old nigah...as i said in the the cruising thread that it was in i have a seat spare..well 2 seats really...but if yah want to come then let me know.
Edited by Oblivion
IF YOU WANT TO DO RIPPING THERE WILL PLENTY OF LITTLE CHILDREN ......
BUAHAHAHAHA
MUHAHAHA
JUST KIDDING FOR EVERYONE WHO THINKS I AM SERIOUS...AND CAPS IS STILL ON...FARKEN.
charity FTW
bogans FTL
by charity i will assume you mean the greedy lazy pricks who masquerade as a charity in order to sponge money from us because they are too farkin lazy to get a real job.
Gotta love the way the bastards use the cripple and dying to make a buck. :thumbsup:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
