u on the piss again?
P.S dinner is at jacks tonite, always plenty of skanks around there :P
how was it.. plenty of hoes at my joint..
yup, gotem bud. sittin here lookin at the size of the holes in 800cc jobs. fark! these things are gonna spray like a gaden hose. :P
BAHAHAHA
thats what i told the waitress too.....she didnt like it.
at first.
dude.. what is wrong with ya lol
not pg2u yet?
YES IT IS.. was mine.. see look up! MINE MINE MINE
Nothing....
oh and dem hoes were good.
lol.. ur such a PIMP
Harro
herro
Looking at an S13 tomora, so help me god I said Id never own one again
why the hell not.. dont u like 1100kgs and weak ass rear ends :P
THANKS DAN FOR THE FRICTION MODIFIER.. stupid CUSCO IS BAREABLE NOW... gonna throw rest of bottle in..
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
