how dare they!!!!???
i got nominated for an exec role... sam nominated me and I nominated sam.. but when we realised who we'd be working with, we both pulled out hahaha
You no my hair goes past my ear lobes if i pull it out, which means it would be f**king long if i straightened it. i can pull it back into a little porno pony tail atm, it looks dirty as.. Im like a dirty porno fluffy guy now.
Lol @ u and sam
You just gotta stop sleeping with dogs...
Its your images im worried about, next you will be attracting bush cops and then you will get bacon, i mean STD's...
Yeh STD's is a worry. *giggles to him self*
Happy bday lizzeh
yeah but not from "find out the name of your perfect match"
lol
yeah i saw those bloody thing...what is the go...this is car site not a porn site....
aww I >3 u. I reckon Id make a good mod
ill vote for you, you would make it a fun site, but still keep in line
+1 for Joshwa
i gtg, have league tonight...
Talk soon, bye LiZZZZZZZ (Ill see you soon, I promise)
Bye everyone else :P
Josh, call me later i might be into it.
ciao man
Hi 5!
I owe you a hug next cruise/meet i come too.
ill hold you too it!!
not for agggggggges... i got a very sick car :unsure: that's costing alot of money.
i should visit soon. i feel slack, I haven't seen bunta and anna for ages! well, not properly!
yeah i will have to meet you next time.
nah you'd be too good as a mod..
i was talking about the fluffy love
i'd be a good mod... I'd just freaking get out the ban stick and unleash a serious assault
byeybeybye
skids in your honour!
so you were.....i think i need to go back to 5th grade to learn to read again..
I love to be held. Hugs rock
dont forget the bum pat...never leave that out.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
