too much pasta makes you fat
its big bowls too like 12cms high lol..
ill work out tonight to the tune of men at work... lol
now he might get a 3071R... u think the 3071R will be fine on a FMIC fuel pump exhast std ecu car on 10psi :D
Disco FTW. Throw that 71 away!
HI DAN.. prices please.. want asap
correct me if im wrong but isnt a 2871R a disco potato highflow.? and 2860RS is the smaller one..?
thats what i told him, but no he wants something bigger...foo!!!
i want to go home.
no u didnt.. jump band wagons much :D wuv u
You won't get fat Mark, 1. You're AZN, 2. You're young, 3. You got one of those friggin super rediculous fast metabolisms
Having a fast metabolism means you'll likely never get fat or even "big" (unless it self corrects later in life), you can build muscle through mass amounts of protein and lifting big weights on a constant basis, but you'll never be huge.
Disco 0.64 $13** inc GST (available)
Disco 0.86 $13** inc GST (available)
2871 -2 0.86 $13** inc GST (EX Sydney - Tuesday)
Euro FTW!!! Nice work Jay!!!! Let the fun begin!!
The interior was NOT as clean as the photos in the ad suggested so it's going to need some love, but mechanically it's great. Pulls speeds I should not admit to very very very easily.
the problem with having a diet of protein and lifting big weights is, if you have a fast metabolism, as soon as you stop/slow down your workout, start a sport or do anything other than continue what you're doing, you'll just go back to the way you were lol...thats why I just go to the gym every now and again, eat a decent diet etc
ok dan what should a S14a with lil mods get.. just want something thats good and makes more power in the future.. i think 3071R is over kill for him... cause i dnt think he wants 250 like i do
You can make 280rwkw on a Disco with SR20. The 2871 is slightly larger and nowhere near as responsive.
Depends on what lil mods he has. FMIC, pump, injectors, zorst, AFM should net him 250rwkw.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
