When i was on od review on bc.com i couldnt post until they approved it. i guess u got the tame mod review on SAU
You have always been on OD review. Such is your nature. :laughing-smiley-014:
Like i give a shit. Mods seem intent on turning it in to an us and them battle which was never the intent. i am over it.
yeh, i'm on 10% warning now too :rofl:
mid 20's, tranny, brisbane.
lmfao!!!!!!!!!!!!!!! farken golden! :P
WTF is mod review anyway??? :P
Means every post you make stays in limbo until it is approved by a moderator before it's visable. It is a feature we have, but you're obviously not on it.
oi squizz, what do the mods do when say a 'postwhore' is put on that mod review? theres obviously gonna be a hell of a lot of posts to review lol
Well if it's a post-whore that's a little "problematic" they usually get suspended so it's a non-issue :P
lol
anyway..
i got the S14's turbo woot.. thanks to dan..
i did unfortunatly rip my front bar off getting into ABS's carpark lol :rofl: luckily for me i had zip ties and i reattached it...:P
and i got a price for the manifold gasket from nissan..............
$116.86 for a friggen mani gasket.. 6layer steel too..
lol
anyway..
sweet brother. now whens the other supporting mods arrive???
haha yeh gasket prices do suck hey.
Well why the hell not??? Ainty i good enough!!!! :P
his S14 has a FMIC and exhaust.. and a Boost controller.. THATS IT.. and im putting a 2876R on it :P it will be running shit all boost for now as im only upgrading due to him blowing a water feed and its cost wise to do it this way..
but ill put a 040 in and run up 180kw worth and leave her be untill the cheap bastard pays me for my efforts..
i asked for a price on the S13 one and i got a reply $17 i just walked out.. ill make one out of a milo tin :rofl:
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
