dad lives over here 3 weeks of every month, and he thought it would e good for me to come over for 2 weeks and stay in his apartment for something to do
so here i am :D
yo shane hypotheticly speaking,
if you had an R32 GTST that had an R33rb26 rwd conversion done its matched up to a 25 box and hardwired DLink ecu
Now take a basicly stock R33 GTST and swap the two engines between the cars loom and all - so the 32 had the 25 from the 33 and the 33 had the 26 from the 32
what are the problems/obsticles to overcome in doing this?
reason being my friend is looking at selling his freshly built car and if i can get the cash together he is considering the posibility of an engine swap
(he has decided to wear a skirt and buy a house)
you can ask me i am doing a conversion atm.....
yeah shane would blab on about r33's and rb26's...and 32's and curse each one....maybe.
but yeah as i said above....if you change everything, then just placement of items and radiator etc, and tailshaft, gearbox mount are the only bits i can think of, but then shane may think of something else.....oh you may need to make room for the different style plenum off the 26, fuel lines.....fuel pump, dump pipes...should change straight off the other car.
space wise should be fine as its a big single conversion
at the moment all i can think of is radiator and dump but they should be easy
how do the engine mounts go?
engine mounts are the same...as all the block castings are the same...as with the rb30.
but probably drive shaft...gearbox mount maybe....radiator.....space to do it...every thing else should match up...
what do you mean by driveshaft?
and the gearbox should be fine cause the 32 has a rb25box in it that th 26 is matched up with the clutch has been changed from pull to push or whatever it is
ahh touche.....if they have the same box in them it wont be a prob...but if the 26 had a 26 box, then the length of the shaft might have changed....i think you need to get a different yoke ...i will find out soon.
only problem i can see is in the loom/hard wired ecu form the rb26 car.
you have 2 options:
a) get someone who knows what they are doing and have wired in a link beofre to un-wire the ecu and transfer it into the other car
or
b) swap looms with the engines
option b would be heaps easier in my opinion, as you could do that urself pretty much, and u know its going to work (well ull have more of a chance of it working :P)
everything else will just swap straight over and bolt up :D
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
