well i've bought a fair few things from greenline lately, and the longest wait has been 7 days (including the weekend lol) plus $630 for a set of injectors, why would u go elsewhere?
mornin :yucky:
yeh mate sards indeed. for anything under 1000cc injectors, i wouldnt use anything else. 1000cc and over thats a different story, mainly because of the prices asked, the differeing brands are then around the same price (~$200 an injector)
*tips hat*
dont lie dave...
About what, pray tell, am I lying Shane??
I didn't throw the drink, you poured it all over your crotch because you thought the alcohol would be an attractant for women of low virtue that inhabit the Logan Hyperdome.
Hi Mark, the pic is from 50 first dates.
ahh so it is daveo... blind hawaiian dude.. ya'll knw im hawaiian.. right..?? tell ur daughters.. its a hit with the ladies..!
Its Mud!!!
hows the icing on the cake with the car? comfortable? done the deed in it yet??
sarp chinos!!??
its gonna last forever like all VWs..
have u taken ur medication today dave?
THIS THREAD NEEDS PICS
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
