sup bitchtits
how was yesterdays cruise?
Yeo Bruce.
yeah man had a blast, man Tim's 33 is da shit, so stock so quite...nice sound system...no mods needed...has a sunroof.
only thing is the driving position is a bit different....had my head half out the sunroof most of the way. drives really well though. doesnt like bumpy roads though a bit low for that, but still good.
where were you yah bum!!!
had a good weekend finally installed my gauges & blue rice led cluster lights, jjr coil packs and some new cheap and nasty NGK's car is transformed it litterally is pulling like a farking freight train, my clutch is screwed now just from booting it as it starts to come onto boost the clutch starts to slip, water pump is also leaking real bad :down:
i hope u get farked over soon josh :)
P.S hi :down:
Me: excuses me, how much longer do I have to wait?
Lady: I don’t know
Me: It’s not good enough, I have been here 40 minutes, and you told me I only had too wait 15minutes.
Lady: Can you come around to the other side of the counter?
Me: How much will it cost to jump the line?
Lady: It doesn’t work like that here
Me: I don’t give a shit, how much? You told me 15 minutes; I’ve been here 40minutes. Your management sucks.
Lady: Josh, you have only been here 27minutes, do I look like a management? I can’t help that.
<centrelink room is now all attention on me>
Josh: 27minutes is not 15minutes; management needs to fix this shit.
Lady: getting angry at me wont help you in this situation, Josh.
Me: Yes it will, I have better things too do then wait f**king here.
Me: Make me an appointment at a more convenient date for me
Lady: I can do 9:30am tomorrow?
Me: Will it actually be 9:30am though?
Lady: It depends how busy everyone is.
Me: This isn’t good enough
<Walks out to the badass 911 parked out the front>
Lady: I don’t know
ha ha gold
Lady: I don’t know
Sarp foos?
Sif your not getting audited in the next fortnight Josh lol
Anyway, just thought I'd say hi before I go out and mow the grass.
Cyas.
i hope u ripped some skids leaving there!
No, 2 weeks ago I parked in a disabled car park at centrelink and I got in a fight with a rent-a-cop over it. who then called the cops. So I’ gotta be could there.
The rent-a-cop paid me out about being a “brat” and how mummy and daddy bought my car, I’m all like dude your clueless. I’m at centrelink for a reason – I’m on the dole mate.
“That would be right, nothing but a dole cheat you are”
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
