i dont know why no one understand it shane, they all think they are awesome at computers and dont understand basic stuff
i dont live at home girly man......now bring me my pie woman
:O
lolz :nyaanyaa:
P.s we're pulling noel's head off tonite :P
wher from home boy
if you dont know how to look for a torrrent then dont use a computer....or if you dont know what one is then do the same.
but just for you my simpleton....google "bit torrent" or "mu torrent" the latter being the better.....download the free progam they have...then use www.isohunt.com....to search for the torrent....
BLAH
dont ask stooopid things again
ah yeah good luck with that, he told me about it last night, hope it all goes alright buddy...let me know...i am going to get my loom tonight.
turbo is fooked too...leakdown found no2 is leaking...
BLAH
3:04pm "Help computer is f**ked" = Poster MarkyMak
"Hey guys down loaded a torrent now my computer is f**ked, gotta post this on my mums computer, what can I do to fix it"
BLAH
i aint no nerd.
BLAH
furthermore www.andr DOT net rules too :nyaanyaa:
Why and how did this happen
replaced welsche plug, noel took it down the road, booted it and it blew it out again.
decided to take head off to see wat's going on. upon removal of turbo found chunks missing from turbo blades, also cracked veins.
fingers crossed the bits of metal went out the exhaust and not into that mega $$ head!!!!!!!
say wha????!?!?!?!
get a virus scanner or firewall you cheapos...
i aint no nerd.
then no more keyboard warrior then...
never been there bish
ditto
cant find rohan...
find what? your pussy?
omg???!?!?! thats gay...warranty?
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
