noel had to go down to 6kg front & 4 kg rear jsut to get the thing to stop bouncing!
however to this day he still thinks the valving isnt the problem :rolleyes:
:P
You retard, So my car doesnt ride well or handle exceptionallly well now huh? I guess it doesnt tuck down and bite when i power up or hold its line through rough corners either.
FARK! i wish someone would have told me this earlier so I could stop enjoying my shitty valving. :thumbsup:
FARK! i wish someone would have told me this earlier so I could stop enjoying my shitty valving. :rolleyes:
did i say it handled like poo? NO! u silly fark, my 12/10kg teins gave a batter ride than ur hsd's, which i mite add were good enough to put down multiple 1.8sec 60 footers :thumbsup:
im going to liken ur car to a pogo stick :P
Horseshit, the car does not bounce and rides extremely well. get some meat on those skinny arse bones to hold you in the seat. :rolleyes:
maybe if u upgraded from them povo-pack std boat r33 seats everything would be a-o-k...plus, not everyone is as 'big boned' as you :thumbsup:
did i say it handled like poo? NO! u silly fark, my 12/10kg teins gave a batter ride than ur hsd's, which i mite add were good enough to put down multiple 1.8sec 60 footers :rolleyes:
im going to liken ur car to a pogo stick :thumbsup:
Bah my GTR did 1.6 60ft on Hankooks. Habib springs FTW!
Why is it game? It's built as a highway cruiser. Better build quailty then some mercs and BMW's that do that on the autobahn. That car owed me in farken repairs alone $13k which I have receipts for, nothing wrong with it now. I just wanted to paint it undercoat and pull the trim out. It's been painted though and looks normal not boro spec.
I never gave the Lexus to dad, I sold my BMW and gave him the money from that. I sold the Lexus to a friend of mine, Bullet on the Goldy is doing a super charger for it.
oh i thought u sold to ur dad.
Horseshit, the car does not bounce and rides extremely well. get some meat on those skinny arse bones to hold you in the seat. :D
ahaha ive told shane to buffen up many times. chicks dig a bit of meat
Yoiu mean you actually owned a car that moved once. :w00t:
zing :sorcerer:
2..both of which died and are/were in bits...much like yours :)
lol cause u buy shit
Sorry what? All I heard was "blah blah blah aids blah blah I need a working car blah blah blah"
zing x 2 :sorcerer:
are you offering to buy me a tt rz supra? :w00t:
dude with the amount u spent on ur GTR i could have brought a JZA80 and build it to put 400kw at the rears all with a turnover time of 2 months haha
and then 1 week after that u'd be onto a 20k rebuild lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
