what you thinking of getting Bunta man..?
ur gay
incorrect. rb20 and 25 differentiate wiith bolt placement
i can post the imageshack link lol... but im not that much of a dick
looking for a chaser i hope..
go see iron chef imports.. he specialises in chaser
if all goes to plan it will be a white evo 8 MR i come up with lots of ideas but i always end up coming back to that
one 10mm bolt lines up differently.. dw bout it rohan dan will explain it to u
yeh 1 bolt is slotted on the later model rb pumps.
however teh pumps dan gets dont ahve this, and are exactly the same
panda or reverse panda. if not, dont talk to me.
:D
good choice.. but chaser...:)
the chaser is too close in configeration to what I have now, and I would have to start all oaver again to make it fast...plus it has no brembos, brembos FTW
i know...and he did and i knew already....cause they are the same....one bolt hole that makes stuff all difference....they are not different black man.
:D
HI EVERYBODY!!!!
:) git down bish!!1
sarp!!!
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
