MMM jam doughnouts with sprinkles on top.
Ill go over to maccas in half an hour too.
I really dont know how i stay in such a magnificant state. Oh well...i guess you can't beat perfection =]
can i buy a ticket?
hurry up and move here, a lot of people from your area are retarded judging by that chat thread
Interview on Thursday, i'll be down Wens in my little hire getz and hopfuly help anna with the tires. Prob stop by on Thurs as well. Job means = josh move = Josh can afford to pull money out for a beater car = Josh gives Andy rent money :P
Cool sounds pretty good! there is a free car in our street it has been there about 5 months now
just went and had an update what a load of shit - bunch of cock smokers!! can we vote people off this forum cause they are a tosser
Hi everyone,
Whatcha think? Should I buy?
R34 Carbon Fibre Bonnet
looks preet good, a mate of mine has almost the same one in silver on his 32 and looks wicked
silver will look good with the blue on yours
I sorta want a huge ass SEL, was thinking 500SEL, but then the v8 fuel in those tanks will cost more then your R33 haha.
See, everyone will think im pretty fly for a white guy. All the 16yr od toeys will froth like mad!
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
