your statment is shit then as i dont own anything.
U fail.
P.s I was in Inara on teh weekend, Its pretty shit
little story....A drunk and an ugly fat chic shared the late train one night. Unable to contain himself the drunk leaned over and said....f**k you're ugly. YOU'RE DRUNK! The fugly replied. The drunk thought for a moment and then said. Yes, I am... But I'll be sober in the morning.
Moral of the story. My car is broke. but it will be sober in the morning. You'll still be ugly and carless....You lose.
See the thing is though, I'm young, I'm pretty hot and I hide behind dads 911. Noosa is more fake then the gold coast, it works for me here.
I win.
I win.
Your dad will not always have the 911 and you will not always have youth. Your win is like the enviro you call home...fake.
The real roses are in ippy waiting for you to smell. (and they aint plastic)
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
