Now the toughie. Who to do an Aussie Capt Slow?
My vote goes to shanef, our own Qld Capt Slow. His car will probably never run, we pay out on him constantly and he just keeps taking it.
bauhahahahaha...
rofl @ whitie
lol that scc thread has turned to shit - good entertainment though!
i pmed this dude cause he said that gonner was stiring people - turns out he had me confused with our friend in the blue 33
http://www.skylinesaustralia.com/forums/in...t&p=3496246
bought 5m of line from my local brake shop, and 10 tube nuts, a flaring tool and a pipe bender and made them up myself.
yeh the plan is to replace all the crap that i can aceess now before the motor goes in for good.
also the box is just there so i dont have to find another place to store it. however that particular one wont be going back in ;)
hmm nice.. i might do something like this oneday.
how muc for the lines and nuts..? i guess dan held ur hand thru this one
So a mate an I went to goldy today to look at the loser left over schoolies, omg there are still a few out! I got respect from all for the Porsche, not too mention brisbane school girls at 3pm!!
I <3 attention
lol joshwa.. should have drove past my house im just off the M1.. give me a call next time u douche..
Shaneypoo...i measured with my stick roughly 3.2m for main hoop, 2.4m for each A pillar. So rounded out to 3.5m and 2.5m x 2 so thats 8.5m plus whatever you want in the 45mm for the back. I reckon 10m worth of the big shit...and the rest in the small shit and then we be jamming?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
