hmm nice.. i might do something like this oneday.
how muc for the lines and nuts..? i guess dan held ur hand thru this one
lol joshwa.. should have drove past my house im just off the M1.. give me a call next time u douche..
was $93 for the line, nuts & 1.5l dot 4 fluid
Shaneypoo...i measured with my stick roughly 3.2m for main hoop, 2.4m for each A pillar. So rounded out to 3.5m and 2.5m x 2 so thats 8.5m plus whatever you want in the 45mm for the back. I reckon 10m worth of the big shit...and the rest in the small shit and then we be jamming?
yeah mate sounds good to me :yes:
not pick me up come past and i follow in either 180sx..
any popo trouble..
You would have slowed me down with your silly 180kph cut.
Yeh pop at the main surface lights along the beach, but they left me alone, heaps of c**ts giving me respect but wasnt doing anything wrong so i guess they couldnt pull me over anyway
sup mud crab
whats kicking king of bling
bahaha my 180 speed cut.. lol.
the RB20 silvia dnt have one.. dnt knw why.. seems to be chipped. hey do factory R32 GTST have speed cut..? :)
You said follow in the 180sx, not the silvia.
An yes they have cuts
whatever.. lol i meant monday same day u post sil was here. lol
COD4.. call of duty.. good game
yay for $1.50 tuesdays..
anyone knw the V0* number for SR filters..?im not using valvoline wanna try pure one
www.nissansilvia.com
lol
I have a crab in my pool. its about 3 inchs x 2 inchs. I have no idea how it got there. Dad reckons maybe a bird dropped it. Idea;s?
Perrigan Beach
we had a toad in ours.. f**ker died to th hand of a golf club!
Blogan
start yokle voice/
we gots a few scorpions an a couple a brown snakes in mah pool - come swimminn at the switch bitch
Ipswitch
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
