TT on a 25PFC. Piece of if you have a clue. Your choice of twin AFM, single AFM, maybe even MAP with a suitable converter. Clearly an old Dingo can't teach himself new tricks.
where do you get this converter you speak of? are they $$$?
thats awesome dude! Still around in its same form?
Sorta... It's got a pfc dejetro now, i had 1000cc injectors which i think he kept, but its now got a fuel cell or something with bigger pumps, last I heard the turbo's where blown up and it was going twin 35/40's or the likes to chase 9's. Pretty sure It now has a PPG box in it too
i jus joined the SAU qld forums, (for some reason hadnt done it yet) and to my surprise, and dismay, rogercordia has plastered his gay ass thread there as well, why....whyyyyy!
lol..
look at the events section ther is a TND come to it
http://www.sauqld.com/ipb/index.php?s=&amp...ost&p=12094
2x hks 25/30's
ORLY...
why HKS..?
If you get caught racing on the highway your obviously not going fast enough :P
...oh dear..
i dnt knw,.. what goes thru ur mind when u get caught racing..?
i remember back in the GTR having a cop zoom past me as i was giving it to a WRX.. well over speed limit out near inala.. and the cop zooms past bottoms out on a bump and i just drove the other way.. wtf..?
oh and i smashed the wrxie
was a few years back wasnt it..
garrett would have been sufficient
I wanted a brand name turbo. Im well aware garrett would have been fine, i just much rather say I have Trust/HKS ect. Some things it doesnt faze me, EG: the pistons werent forged jap items
Plus the RnD on cars built somewhat the same, incl RH9 cars made the choice easyier to pick the HKS
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
