A friend of mine is a trainee accountant.. Fridays are casual clothing. one of teh PA"s bought him a pink barbie shirt (yes im jealous) and will give him $50 if he wears it the whole day.
We are going shopping for hand bands Thursday night.
Who wants pics?
i want pics...of said PA :P
She is a little chubby, but cute. Her friends are MINT, most of which live in brisbane... There is a theory behind my mate beacoming better friends with teh chubby PA :P
hahaha i hear ya
office bitches are mint :yes:
on that note. im outta here :D
Actually i think "airhead" is timeless Josh. :P
I googled the meaning..
Someone who has nothing but air filling the space where their brains should be. Typically used to describe a teenage female who is dyed blonde, cute pretty and ditzily dumb.
I think I was meant to have a vagina?
The roadside testing only gives you a good/fair/poor raiting, and it's only a optional thing to go get it checked out?
What I am asking more is can you be sent for testing by police/qldtrans and if you fail your car is deemed unroadworthy?
well as far as I know it can kinda go a few different ways:
1: Get pulled over for "RBT" get defect for xyz depending on seriousness of defects they will tow or tell you to drive it home
2: Go through a roadside Transport department trap usually after a booze bus they will often do the road side checks for noise maybe emissions here if it comes up bad they will tell you to either go to qld transport office with it fixed and show proof not sure if the "pits" are still around though
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
