lol hey thats the highest post count i have on any of the forums i frequent
that being said what other forums do you guys use?
I use them all, although i post the most on this one.
ns.com
pf.com
bc.com
and other car ones
And a few american car an non car forums
computer is giving me the shits: Anyone know why all of a sudden when i save a file it defaults back to the "documents" folder rather than the folder you have been working in?
why its sucks is i make a document then export a pdf for client approval and every time i make a pdf it defaults back to documents folder so you need to navigate back through the folders to the client folder your working on?
make sense?
its shit and takes up my valuable time.
u need to edit ur adobe pdf printer driver
load up adobe, open a pdf file, go to print, select the printer as "Adobe PDF", hit the properties box, under the "Adobe PDF Settings" tab theres a dropdown for "Adobe PDF Output Folder", hit the browse button to the right and selcect the location u want it to default to. hit ok and ok again and then it should be set.
thanks shane
I don't think that will work for me as I'm not really "printing" pdf's as you would in most other applications I am using the pdf export feature, and this is happening across the board not just exporting pdf's its saving / save as
if you creat a file save it in a folder then wanted to save a copy of it you would "save as" usualy it would default to save the file over the one you just created as it would be going to save in the same folder - mine is constantly defaulting back to the "documents" folder
AAAARRRGH!
otherwise, just make a copy of it in the same document, and grab the scale tool and scale it up to match,
or jus work out 35% of the original dimensions and then enter what the original dimensions would have been for the small image
BAH...what program are u usin..
Edited by RusH_
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • To what gain?
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
