that kid is the biggest dipsht, and to top it off, no remorse... i hope they do get slapped wit the $20,000 bill, and that kid gets kicked in the ass
oh and frm what i can tell...joshie ol pal...u dnt look much alike...tho u may sound it? hrmm
Edited by RusH_
yeh that would be great man how much it cost? I had a chat to my tuner he said he could do it for ~$600 less if not polished
he also recommended buying a gtr style cooler for the end tank design anyone care to comment on that?
I got a uleh fulley sick BOV yesterday it is purple!
yeah i just put a gtr cooler on cause of that reason...they flow better then the other styles.
i think it cost about 200 but he didnt do it all...:S but prob about 500 for all i guess if you have a forward facing plenum.
does anyone know if there is a harness or sumtin i can get so that i can use to hook up my sony headunit in my 34?, there are 2 harness thingies goin into the back of the double din unit that is already in there, which is factory by the looks of it as it has a nissan sticker on the back of it when you pull it out, but only the one harness socket in the back of my sony single din unit...
oh btw dan, had an interview wit glenda stenner this evening, was quite interesting, kinda an odd woman that one, when you saw her did you notice her writing some shit in some sort of code? lol
cos i watched her writing aafter my responses to questions, and its all these squiggles and stuff all over the page....weird
good stuff mate! yeh she is a colourfull lady you will get used to those types of excentric types in this industry and the squigily stuff is "shorthand" they used to teach it to everyone who was gonna do office stuff back in the day wiki it
You guys will be do proud of me, josh has been doing interviews an such proactive things haha
omg not work!!! ! :)
or is this some kind of scheme you have worked out so it looks like you want to work in the eyes of centerlink
what do you reckon bout this will it do the trick for a while?
i personally woulndt use it
collector looks poor, and it does not look tuned length
plus its stainless so its not gonna last all that long
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
