Aren’t they meant to show an train you new things? Douche bags scream its not in your AWA
yeh, they trained me a lil, but then the guy that is my senior took extended leave, therefore i have 2 and a half weeks of shit on my own, im the only other person who knows how to do my job sides this other guy, so there is all this guessing, and im playing with thousands of dollars of vinyls and stuff... :P
Edited by RusH_
whats happenin dano, im so fkn hungry, i feel like im about to pass out, think i mite head down to audio express this afternoon if i can to get myself a harness kit for my stereo... :D mp3'ssssss, no more 20 track cd's
then again i cant wait to get a dvd headunit, double din stylin...dvd mp3's ftw lol
not much Cheif...just looking for something to do at work...kinda been at a loose end for that past 7 hrs....
u say that like its a bad thing, im leavin in like 5 mins, hehe
Edited by RusH_
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
