got torque????....
and no revs!!! ;)
jk..farken monster!!!!
lol
myeah mine wont be doin over 7k so i guess thats about the same really.
oo that should flow really well but still have some nice response. it will be interesting to drive against you on track of course.
softcock, rev it til it stops making power...
im probably set my limiter to 7200 as thats what robbie (RIPS) recommends the motor is built for
would be good to have a built 25 reving to something spastic like noels but Im sure my wallet has so far been considerably less damaged than noels!
how many rb30's have died from over revving? i havnt seen any
minell be making power upto around 9000-9500, im confident itll be happy at them sort of revs
You're going to need to make some oil gallery modifications if you want to run it at 9-9.5k and think about buying a forged crank.
The RB30 isn't designed to rev that high reliably especially when you are going to be making 700awhp.
Speaking of which, I need to talk to you about those modifications you will need to make....and it's not doing any dumb shite like knife edging the crank.
we need to talk...
Hey Col what is the go with the user sigs?
Mine is cut off at the last part of the pic, it is one whole pic and I have noticed quite a few others with halve a line of text at the bottom.
yo shane you back on the 3L thing - just trying to make sense of all that went on in my absence lastnight?
ive never been off the 3l thing lol
speaking of such, 3hrs of machining to go on my girdle, i hate weekends and public hollidays :D
try installing ie6 - it dont like ie7 and the smart cookies of sau reduced the sizes of the sigs - genious' :D
:rolleyes:
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
