When I saw that photo it reminded me of a night I had in my younger days, when I woke up they were gone...
Along with my wallet and my phone and my keys... :D
Baaaaaaaahhhhhahahahahah :happy:
Please tell me your serious!?!?
I was pissed (angry) at the time, cost me like $50 for another drivers licence, had to cancel and re-order all my cards. Which is impossible with no id...
Had to change the locks on the house, had to replace the alarm and central locking on the car (as they had my alarm flob as well as the key)...
In hindsight it was worth it... :blink:
aaaaaall riight :blink:
dont wana say oy col, but, pics or ban
there is still blondes i would do i just wouldnt tell my mates about it
oooooooooh ofcourse, Agnese *sigh* so beautiful, so foreign, so dumb :)
I rest my case :cool:
Ah, a classic fake girl kiss. Gotta love that just barely touching look :D
Along with my wallet and my phone and my keys... :(
HOLY SHITBALLS!!!!!!
That is hilarious. i'm e-hi5ing you right now!
And them for having such an ingenious plan :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
