What the hell ?
I bought some anti-oxidant vegies ( by mistake ) for chicken soup and these things that looked like broccoli fell apart and have now made my soup look like some weird dark green goo
What the hell are these green things of doom ?
In what world are you going to get 400awkw with 5k? The Z tune has a lot more to it than just throwing a load of branded parts in. They were all stripped back to a bare shell and everything was completely rebuilt. After it was all spot welded etc. The amount of labour in building a car like that is ridiculous.
Would anyone with a Z tune swap it for a 35 though? I doubt you would get a z tune for under 400k tbh.
I would buy a Z tune if I had the cash.
Who said anything about ztune? That car on advertisement is a M-spec NUR. Not a ztune. I know how the ztune is built. And some sources told me that car was brought into aus for less than 200k and now sold to Greece for an unknown figure.
Tristan: You have fail you notice the fact that I'm running way lower boost (16psi) than what I am suppose to be running (22psi). I thought the redbum in you has long disappeared along with the thrash he left behind.
Think about it logically if I'm running close to 90% duty cycle on injectors with 16psi why wouldnt I hit 300awkw when I run 22psi at 98% duty? If I really need to, I can just change injectors and get a fuel regulator. If original boost was at 10psi and by going to 16psi I get from 165awkw to 255awkw, I think an extra 6psi for 50awkw isnt too over the board yah? The N1 turbos or GT-SS should be ran between 20 to 25 psi anyway.
Colin: I'm not saying 400awkw with 5k I'm saying you dont have to spend 50k extra to get 400awkw. Considering the 34gtrs are more refined than the precendents, remember the topic is on the 34 Mspec NUR not just an mspec. The NUR engine if I'm not wrong is equivalent to an N1.
I know a guy in perth that has a vspec 2 nur running slightly over 350awkw with what I said, ecu, ebc, injectors, afm and fuel pump.
lol im not talking on behalf of redbum, i just recall you claiming you will make make 300awkw on stock inj, and myself and others saying that you'll need bigger injectors - that is all
Nah. Like I said before, proven and done before (2 33 N1 owners). However, everyone is right about fuel. I WILL need more fuel if I want to run higher power down the road, that I agree. But if you have absolutely no plans for anything more, why bother? Same concept as why I dont wanna get a dejetro or vipec. If you dont need it dont get it. Its only when you have the mentality of "oh its only a little bit more extra, maybe I should get that" then you'll end up spending a lot! Same deal with Maccas' upsizing! Doesnt work for me :blink:
Same thing with launching gtrs at 7000rpm. What was the response when I mention that? If you remember.
ps: I lied, I launched 3 times at that kinda rpm and ran 4 times...
+1
its the same as the electric motor principle, you'd understand ur an elec engineer. why put a small elec motor to do a bigger motors job as it will put undue stress and cause it to wear prematurely. and why put a bigger motor to do a small motors job as it will run in-officiant and cost you more. same principle applys to your injectors.
in your case your injectors at 22psi (98%) is the small elec motor. hence why your tuner has advised the 16psi.
+1
Nope toooo serious for me at the moment
I'm out
Tuner didnt advise 16psi. I SAID MILLION TIMES. Its not holding boost for some reason and I suspect actuators or ebc. Which I found out later that the apexi ones are shit. He told me he's got another customer running apexi got the same problem too but when he switched to evc 6, problem gone.
Anyway that said, I still think I'm right about the achievability of that power with stock setup but I have fallen. Next mod after suspension is injectors and ebc or fpr and ebc.
no you said with your current set up you'd make it
enough back peddling, im over the 300kw discussion
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
