Woo! And I'm buying him a present Tony, not you ha ha also how good is he at reading analogue clocks?
And Natro, I'll buy you a present for your birthday right now ALL my money is going towards groceries and my 21st ring.
Haha ill hold you to that, 12 September :P
What exactly is a 21st ring?
Its a ring that you give as a gift on your 21st birthday.....not too fond of rings as the last one I got = marriage
Know the feeling. Wasn't married but close enough to it. Farkn men, takes house and cats, leaves me with the kid :/
Was a pretty ring though
My brother and I had a couple of glasses each and then he left it here. We actually bought our Managing Director a bottle of johnnie walker swing to commemorate 20 years in the industry.
Was very yummy. Would have gone perfect with your marmalade ham
Wow. Looks like you got wrong end of the stick. Usually it's the other way around (no offense)
But at least you have a wonderful toddler.
Nice. Il throw up a pic of my collection. I also have the JW Swing :)
Ask and y'all shall receive :D
Highland Park - my fav and the best spirit in the world (the title for the 18yo HP) just excellent
HP 25 YO (VERY EXPENSIVE!!!) Recently scored 100 points (a whisky drinkers whisky they say but at 47.5% proof its a real knock out :cool: )
My current taste buds prefer Glenfiddich - just a unique whiksy and that Malt Master is pure sex in your mouth
also have the JW collection - not a fan of blends (good with coke cola or lemonade)
one for Tony - that XO I recently opened is sensational after a nice dinner
I have plenty more that will do for now
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
