It's from anchor man :)
Correction futurama season 3 ep 5 Hahha was just on foxtel
Close by no cigar. It is futurama but its from season 3 episode 1 Amazonian women in the mood
Here is my pick up line of the day
I find the most erotic part of a women is the boobies.
Now if anyone can tell me what tv show that line is from and the episode name I will owe them a beer or a reach around. Their choice
think this should make u happy.. http://now.msn.com/squeezing-breasts-can-stop-cancer
morning all...
  • Like 1
uh uh hellll no
i want my reach around :P;)
http://www.imdb.com/title/tt0149460/episodes?season=3&ref_=tt_eps_sn_3
did you get your info from wikipedia..... :yucky:
Nope straight from the dvds. The Australia and American season must be different for some stupid reason
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
