that sucks man, lucky for the dog he was largish. unlucky for your car. Owners of the dog should pay for this if you weren't doing anything silly.
I wasn't doing anything stupid that's why I'm so angry. Was putting down the road
I SO WISH!!
Gotta clean my room and go back to work and finish off some work that I don't to this arv because I wanted to leave early than I have to go to an 18th
No worries mate. Catch up next time ;)
I should put these covers on my real brembos for extra stopping power
Seen it, looks funny as the real thing sticks out from the stupid plastic covers....
check out the caliper covers....
good spotting, can't say I honestly looked that closely.
had one for work years ago, tough little thing, not the nicest on road manners though!
to be expected for an old design. It's a good sign that you actually bought a work ute.
I like the d22.
I see them as the true 4wders 4wd.
none of this auto 4wd and auto locking hub crap.
agreed, the electric everything on the newer thing is just horrible, fly by wire throttle is the devil......and don't get me started on clearance.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
