All I'm hearing is "wah wah wah I built a look at me car and now realise it's slow and expensive so I'd better throw out any and all cliche V8's are better lines and hope noone notices my little man tears".
*inserts V8s are better line* Built with spanners not chop sticks, yeah take that. Skid comp? Lets see your POS sooby do that... Ill meet you at centerlink at dawn! :devil:
Now where did I put that blasted beer can
Smoking 4 tyres > Smoking 1 tyre
Saves him wasting dole money on two tyres at once when you can just swap non-directional Bob Jane All-rounders from left to right.
Blue streak eagles brah, none of this expensive bob Jane stuff
"My stay"? Look who started this thread.
You said that you retired. If I replace stay with visit, will that make you happier?
Lol!
Dude... Seriously....
Lol! Can it take out the Unicorn?
Lol! Well played. With comments like this, we need you commenting here more often
What's been done to it? Also, I am officially inviting you to dinner with Jim Richards.
The cars are probably line ball, though he has better suspension and brakes, but I dont mind saying that Jay is probably the best driver I know by a significant margin so I doubt I beat him at anything lol
Oh no, not my dead standard motor how dare it not be an awesome dedicated drag car on its second run at the strip damn and blast to hell
Is your car awesome or shit? Because you talk about it like it is awesome...but as soon as some one challenges your times its a junker. So what is it?
True
Edited by Bunta
Lol!
Yes seriously everything I say in the whoretown should be taken as gospel truth :ph34r:
True
It's awesome, just to clarify that for you :thumbsup:
Well in that case "its stock" "I had crap tyres" or " It was its second run" are no longer valid.
Its awesome and the time it ran is 13 sumthin sumthin in spite of being awesome. Thus closes the case of the people of whoretown vs natro. The court rules in the favour of the people of whoretown.
True
All that says to me is you need to meet more drivers LOL
I agree that they would be similar around a circuit, but you should have me at the drags. The gearing in my 6 speed is not the greatest for the strip.
CoR33vettes are always awesome. In the same way that herpes just doesn't leave, to some people that's pretty awesome.
Objection on the grounds of duress...
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
