Yeah but thats a different kettle of fish, its not a 'nice' car its a track car. More and more nowadays I care not for track cars
Ok then, the other other one. Han's is comfy as.
But not the other other other one, it's slow and horrid.
I used to own a red MY99 WRX and went very well for minimum mods, but then I purchased a near dead stock R32 GTR and said to myself "why did I ever bother with a WRX?"
My current daily STI is far nicer than my GTR ever was. It's cheaper to run and insure and so far is only 0.3sec slower down the quarter for similar mods.
It also has an oil system that doesn't try and lunch my motor whenever it sees a long bend in the road.
That being said, when I had the GTR I swore black and blue I'd never have one of those WRX buckets of crap.
A stock wrx to a stock STI is more of a performance gap than people realise too. You wouldn't assume a GTSt was just like a GTR would you...
An STI at that time was a lot better than a WRX.
Pretty much went to shit when they jumped to the 2.5L motors.
- not entirely fair to the 06/07's though, they seem to not be made of the same paper-mache of the 08+
I've never said the WRX (STI) was a bucket of crap! I have a strong affection for the Nissan GTR's that will always run much deeper in my veins than the Subi will ever will.
Really discussing oiling issues on the RB's?!
I've driven both the standard WRX and STI (type R) and performance wise...........well it did not really give me a hard on.
What happens in your pants is your business and yours alone my friend...
Evidently you can pop back in once every few years and not miss anything of substance.
There has never been anything of substance.
Speaking of no substance all we need is Josh here for true and proper whoring lol
And Gordo, and Nex, and Cyrus, and Charlie - actually fk Charlie.
A Falcon mobile :woot:
Holden bloke... Soooo pass and I'm more looking for a small car
I swear I replied to this but it didnt show.
I had an excel a while back. Unkillable and cheap. Averaged around 6L/100, parts cost next to nothing and I didnt service it for 35000km and i stayed alive. As a runaround it was pretty amazing.
Pass my sister had one nothing but problems and i hated the thing hated working on it hated driving it juststraightuphateit
Bought It off her for 100 went for a skid day in a paddock on a mates farm rolled it a few time. Blew the motor and burnt it. Best thing the car did was burn
And tony that's a possibility, but wanting a small car like a mirage, starlet, rolla or something like that a little hatch
Johno / W4NTED is selling a Charade...
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
