Why is that good?
or did you mean to say NOW an Engineer
Oh god, I do indeed.
Would hate to have done the graduation in summer, being in all that stuff for a few hours is bad enough when its not super hot!
Was anyone else drinking anything nice last night? This does not include rum or bourbon...
I had green fairy absinth (did an admiral zeke toast before the shot), some pre mixed cc and dry and few caronas a raspberry cruiser two double blacks and some American honey...
Drink with dalton they said, it'll be safe they said :/
And you wonder why people think you love the tube steak....
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
