Why is that good?
or did you mean to say NOW an Engineer
Oh god, I do indeed.
Would hate to have done the graduation in summer, being in all that stuff for a few hours is bad enough when its not super hot!
Was anyone else drinking anything nice last night? This does not include rum or bourbon...
I had green fairy absinth (did an admiral zeke toast before the shot), some pre mixed cc and dry and few caronas a raspberry cruiser two double blacks and some American honey...
Drink with dalton they said, it'll be safe they said :/
And you wonder why people think you love the tube steak....
