Current Squizz hasn't slept for 3 days and is grumpier than normal, thus doing his very, very best to preserve the sensitivities of the current tampon-inserting Whoretown crowd by not kicking sand into their vaginas.
lol
At Bundamba Poo Farm.....
Fun times!
So when you getting back into a skyline timmy?
Hardly, but if you've spent the time and money building your car why run inconsistent fuel and risk your motor when there's a proven and stable solution available?
this is understandable for a built engine that sees a hard time.
but when it comes to daily duties, 95 or higher from the local servo.
And we appreciate your sensitivity, and we shall as a group do our best not to kick sand into any of your many female openings... If I didn't know better I'd say u were a vegetarian
#ifyouknowwhatimean #southpark
This amounts to "I am rubber, you are glue". I thought you had potential.
Good morning all!
Mr Antz,
I have a question for you regarding the new novated leasing rules. I am considering entering a novated lease, the car is for 100% private use, not one of those deals where I use it for work and home. Do the new rules effect this type of lease? Cheers, Andrew
  • The proposed changes in relation to car FBT take effect to all new contracts entered into after the 16.07.13 - so you would fit that description
  • The changes basically mean that the more concessional FBT method (the statutory method) has been binned and more FBT revenue will be captured
  • However, the start date of the new rules is quiet conflicting as the statutory formula can still be used for the remainder of the 2014 FBT year (1 Apr 13 – 31 Mar 14). Subsequent to that date only the operating cost can be used.
  • This means the employer must use the operating cost method when calculating the FBT payable on the car they provide to you and involves keeping track of all costs of operating the car for the FBT year
  • There is much uncertainty regarding this pronouncement considering the amount of lobbying from large car manufacturers and the private sector
  • There is even more uncertainty as the coalition have indicated they will oppose this measure and remove it if elected into Government
  • In your case Andrew, I strongly recommend you enquire from your employer what policy they are going to adopt regarding the proposed changes. If they are unclear, advise them that you can still use the statutory method until the next FBT year.
  • Please remember that, in order to make this arrangement effective that precise details of the arrangement between you and your employer needs to be governed by a written salary packaging policy and should include the following:
  • The total cost of employment (TCE) which includes cash salary, superannuation contributions, the cost of the benefits provided and FBT payable by the employer) should not exceed a certain remuneration amount
  • GST credits are added back to the employers package (because they can claim it back if they are GST registered and I highly doubt they are not GST registered)
  • GST is payable on any contributions you make to the package i.e. if you pay for fuel.
  • I do hope all of the above makes sense to you, if not just let me know.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
